[Qgis-developer] Geospackage Slow in QGIS
aperi2007
aperi2007 at gmail.com
Mon Aug 18 14:55:35 PDT 2014
Hi Zoltan.
Yes, this is the usual solution in the sqlite world.
I don't like it because is not a scalable solution when there are many
records and there are relations with other tables.
Also an usual problem is to have a primary key filed with the same
values of the original table.
The solution
create table as select ...
dont allow to have a primary key field of type integer incremental.
It need a more uggly
create table(...);
insert into .... select .....
But also this don't allow to have the same pk for the same records.
A.
Il 18/08/2014 22:41, Siki Zoltan ha scritto:
> Dear Andrea,
> what about using DB Manager's SQL window?
> There you can input an SQL select.
> To remove a column in SQLite you can create a new table without the
> column to delete and then use
> INSERT INTO new_table SELECT ...
> Regards,
> Zoltan
> On Mon, 18 Aug 2014, Andrea Peri wrote:
>> Just to explain why this is an important question.
> On a sqlite db is impossible to remove a field.
> So if a table is with two geometry field, it is never see-able from qgis.
> Because is not possible a command like:
> alter table remove filed geometry-2;
> Bye,
> Andrea Peri.
> 2014-08-18 16:52 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
>> Hi,
>> I have changed my opinin.
>> From +1 to +0
>> Infact I discovered just now that gdal driver for spatialite don't
>> seem to support tables with more than 1 geometrt field.
>> Almost on QGIS.
>> Andrea
>> 2014-05-17 22:19 GMT+02:00 Jeremy Palmer <JPalmer at linz.govt.nz>:
>>> I'm wondered why QGIS needs a native SpatiaLite provider and
>>> connection dialogue any more. Unlike other database providers such
>>> as PostGIS, Oracle, MSSQL the SpatiaLite provider doesn't seem to
>>> have anything special that requires a QGIS provider. From a users
>>> perspective it just adds to the confusion and complexity for adding
>>> data. Why not just use GDAL/OGR for both Geopackage and Spatialite?
>>> Cheers
>>> Jeremy
>>> ________________________________________
>>> From: Stefan Keller [sfkeller at gmail.com]
>>> Sent: Sunday, 18 May 2014 12:24 a.m.
>>> To: Martin Dobias
>>> Cc: Jeremy Palmer; qgis-developer at lists.osgeo.org
>>> Subject: Re: [Qgis-developer] Geospackage Slow in QGIS
>>> Hi Martin
>>> It has a different binary encoding compared to Spatialite.
>>> And in addition it integrates raster tiles (MBTiles) and metadata.
>>> -S.
>>> 2014-05-17 14:10 GMT+02:00 Martin Dobias
>>> <wonder.sk at gmail.com<mailto:wonder.sk at gmail.com>>:
>>> Hi
>>> On Sat, May 17, 2014 at 2:32 PM, Jeremy Palmer
>>> <JPalmer at linz.govt.nz<mailto:JPalmer at linz.govt.nz>> wrote:
>>>> I've just been using the new implementation of Geopackage in QGIS
>>>> :) However each map render or feature info is very slow for large
>>>> database files - even with the new GDAL/OGR Geopackage spatial
>>>> index support. Each time QGIS renders a new map view or executes a
>>>> feature info it re-opens the Geopackage file in
>>>> QgsOgrFeatureIterator via OGROpen, and the Geopackage driver open
>>>> method runs PRAGMA integrity_check which is very slow (4 secs with
>>>> my 2GB test file). This integrity check is actually a Geopackage
>>>> requirement.
>>>> How can this be fixed? At the in QGIS or GDAL/OGR level?
>>> Actually I am wondering how different is the format of GeoPackage from
>>> the format of SpatiaLite... we could use our native SpatiaLite
>>> provider also for GeoPackage files if they are close enough. Any
>>> ideas?
>>> Regards
>>> Martin
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> This message contains information, which may be in confidence and
>>> may be subject to legal privilege. If you are not the intended
>>> recipient, you must not peruse, use, disseminate, distribute or copy
>>> this message. If you have received this message in error, please
>>> notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and
>>> destroy the original message. LINZ accepts no responsibility for
>>> changes to this email, or for any attachments, after its
>>> transmission from LINZ. Thank You.
>> Andrea Peri
>> qwerty ˙˙˙˙˙˙˙˙˙˙
