[Qgis-developer] After upgrade all fields are editable in QGIS project file
Markus Innerebner mailinglist.innerebner at gmail.com
Tue Aug 19 01:42:14 PDT 2014
On 18.08.2014 19:28, Matthias Kuhn wrote:
> Hi Markus,
> is it possible for you to download a nightly build or weekly build and
> see if the same thing happens if you open your 2.2 project with this
> version of the software?
Hi Matthias,
I compiled QGIS with from the aur repository. I will try to download and
compile QGIS using the nightlybuild. And then I will inform you about
the situation.
kind regard
Markus
