[Qgis-developer] [Qgis-user] Segfault when using QgsComposition::exportAsPDF with QGIS 2.4 and python
kimaidou
kimaidou at gmail.com
Wed Aug 20 00:29:43 PDT 2014
Nyal,
Thanks a lot, you find it !
When instantiating QgsMapSettings first, then use this object to
instantiate QgsComposition, this works well with no segfault.
Without your help, I could have spent many times on this issue without even
noticing this small difference. Thanks a lot again !
Is it still an issue, though, or should I close the issue I added in the
hub ?
Best wishes,
Michael
2014-08-19 22:48 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 20/08/2014 2:58 am, "kimaidou" <kimaidou at gmail.com> wrote:
> > Hi again,
> > I have opened an issue in the hub : http://hub.qgis.org/issues/11077
> > I have not assigned anyone, please assign the adequate dev ;)
> Does it make any difference if you change:
> c = QgsComposition(QgsMapSettings())
> To:
> ms=QgsMapSettings()
> c=QgsComposition(ms)
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140820/083c7b4d/attachment.html>
