[Qgis-developer] [Qgis-user] Segfault when using QgsComposition::exportAsPDF with QGIS 2.4 and python
kimaidou
kimaidou at gmail.com
Wed Aug 20 02:39:41 PDT 2014
Thanks Nyall and Martin for your help.
In my plugin I get around it by storing the instance of QgsMapRenderer or
QgsMapSettings (depending on QGIS version) in a class property; which I
then use the instantiate QgsComposition
Could you please comment on the issue to keep track of it ? (or close it
and open a more generic one ?) http://hub.qgis.org/issues/11077
Kind regards,
Michael
2014-08-20 11:23 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 20 August 2014 19:16, Martin Dobias <wonder.sk at gmail.com> wrote:
> > Hi
> >The QgsComposition should be fixed so
> > that it does not require QgsMapSettings/QgsMapRenderer - after all, it
> > does not make much sense, there may be several composer map items with
> > different configuration. Each QgsComposerMap should have its own
> > QgsMapSettings instance.
> Agreed. I guess we'll have to live with this until the next API break.
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140820/6f9f5467/attachment.html>
