[Qgis-developer] Building QGIS with Microsoft Visual Studio in Windows 7
otmane yazidi alaoui
yazidiotmane at gmail.com
Thu Aug 21 13:57:38 PDT 2014
I sincerely thank you for your help
I got the following result
QGIS Version: 2.5.0 Master (20500)
Could not find GRASS
Found Proj: C: /OSGeo4W/lib/proj_i.lib
GEOS Found: C: /OSGeo4W/lib/geos_c.lib (3.4.2)
Found GDAL: C: /OSGeo4W/lib/gdal_i.lib (1.11.0)
Expat Found: C: /OSGeo4W/lib/libexpat.lib
Spatialindex Found: C: /OSGeo4W/lib/spatialindex_i.lib
Qwt Found: C: /OSGeo4W/lib/qwt5.lib (5.2.1)
Found Sqlite3: C: /OSGeo4W/lib/sqlite3_i.lib
Found PostgreSQL: C: /OSGeo4W/lib/libpq.lib
SpatiaLite Found: C: /OSGeo4W/lib/spatialite_i.lib
Found Qt Version: 4.7.1
Touch support disabled
Qscintilla2 Found: C: /OSGeo4W/lib/qscintilla2.lib (2.6.2)
Pedantic compile settings enabled
Found Python executable C: /OSGeo4W/bin/python.exe
Found Python Version: 2.7.4
Found Python library: C: /OSGeo4W/apps/Python27/libs/python27.lib
Found SIP Version: 4.13.1
Found PyQt4 Version: 4.8.3
Found qscintilla2 PyQt4 module: 2.6.2
GSL Found: C: /OSGeo4W/lib/gsl.lib C: /OSGeo4W/lib/cblas.lib
txt2tags not found - disabled
Ctest Binary Directory set to: C: / dev / cpp / build3 / output / bin
Configuring done
Generating done
ca mean that all works fine on cmake
but when I open my solution in vs Express
I have this result:
187> Compiling manifest to resources ...
187> Microsoft (R) Windows (R) Resource Compiler Version 6.0.5724.0
187> Copyright (C) Microsoft Corporation. All rights reserved.
187> Linking ...
187> LINK: fatal error LNK1104: can not open file '.. \ .. \ core \
RelWithDebInfo \ qgis_core.lib'
187> Build log WAS saved at "file: // c: \ dev \ cpp \ build3 \ src \
providers \ wms \ wmsprovider.dir \ RelWithDebInfo \ BuildLog.htm"
187> wmsprovider - 1 error (s), 0 warning (s)
========== Build: 74 succeeded, 114 failed, 69 up-to-date, 0 skipped
you have an idea on how to solve this ??
thank you a lot
2014-08-21 16:45 GMT+00:00 Jürgen E. <jef at norbit.de>:
> Hi Otmane,
> On Thu, 21. Aug 2014 at 15:30:06 +0100, otmane yazidi alaoui wrote:
> > Hello everyone
> > I ask you, what I am doing is right or not ??
> > I really am stuck
> > thank you very much
> > > I change the value of:
> > > PTYHON LIBRIRY T to C: / OSGeo4W / apps / Python27 / Lib
> Why? PYTHON_LIBRARY points at %O4W_ROOT%/apps/Python27/libs/python27.lib
> in
> package.cmd
> > > 2> ------ Build started: Project: processing-26-stageinstall,
> > > Configuration: Debug Win32 ------
> > > 2> Performing Post-Build Event ...
> > > 1> Generating qgsexpressionparser.cpp
> > > 1> m4: can not open `Files \ GnuWin32 / share / bison ': No such file
> or
> > > directory
> > > 1> m4: can not open `C: \ Program: No such file or directory
> > > 1> m4: can not open `Files \ GnuWin32 / share / bison / m4sugar /
> > > m4sugar.m4 ': No such file or directory
> bison.exe (or it's m4) apparently doesn't like to be run from a directory
> with
> blanks. Try installing into a directory without blanks.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC) Germany IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
YAZIDI ALAOUI OTMANE
Ingénieur d'état en Géomatique
Tel:+212652538743
@ :yazidiotmane at gmail.com
http://www.doyoubuzz.com/otmane-yazidi-alaoui
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140821/6d956521/attachment.html>
