[Qgis-developer] Python plugins mandatory metadata
Siki Zoltan siki at agt.bme.hu
Wed Aug 27 01:07:46 PDT 2014
Hi all,
+1
I suppose the plugin approver should check if all the sources are
available in the source (if no code repository is available), e.g. ui
files. It would be important for those who would make a fork of a (already
not supported) plugin.
A minimal documentation in the source may be obligatory.
Zoltan
On Wed, 27 Aug 2014, Matthias Kuhn wrote:
> I would also prefer to keep the entry barrier low.
> I.e. if a hobby-programmer does not add these fields to his plugin but
> will happily make (the missing bits) of the source code available on
> request (GPL states on request IIRC) it should be possible for him to
> just upload the plugin, but get warned that he could make people a lot
> more happier if he would set these fields. I can imagine people
> struggle with git, do bugtracking by email or on an internal tracker,
> don't have a homepage... But still make good plugins which could
> eventually evolve into projects with all these parts included. There
> are a lot of other things people can fail at. And just make these
> things hard requirement because they are easy to check does not feel
> right for me.
> I would also vote for the solution of having different repos (
> recommended, bood, creepy )
> Matthias
> Qgis-developer mailing list
