[Qgis-developer] line renderer and composition mode
Jürgen E. Fischer
jef at norbit.de
Wed Aug 27 05:53:14 PDT 2014
any objections to have the line symbol layer render in composition mode
"source"?
I have a layer with multiple levels of administrative boundaries, where higher
level boundaries (eg. state) lie over lower level boundaries (county). Lower
level boundaries should not be visible if there is a higher level boundary on
top of them. The styles are dash-dotted - so the lines don't fully cover the
lines below.
I could solve that by putting a white line on the bottom of the symbol, but
that would also mean that layers below are covered, that I still would like
see.
Rendering the line in "source" composition would allow to have a fully
transparent line symbol layers on the bottom of the symbol that would overwrite
the already rendered lines on that layer with transparency.
Is that already possible in a different way (without resorting to multiple
vector layers) to achieve the same? Or does it introduce some problem that I
didn't think of? It could still be optional...
Jürgen
diff --git a/src/core/symbology-ng/qgslinesymbollayerv2.cpp b/src/core/symbology-ng/qgslinesymbollayerv2.cpp
index 5a06f23..e21474a 100644
--- a/src/core/symbology-ng/qgslinesymbollayerv2.cpp
+++ b/src/core/symbology-ng/qgslinesymbollayerv2.cpp
@@ -207,10 +207,12 @@ void QgsSimpleLineSymbolLayerV2::renderPolygonOutline( const QPolygonF& points,
return;
+ p->save();
+ p->setCompositionMode( QPainter::CompositionMode_Source );
if ( mDrawInsidePolygon )
//only drawing the line on the interior of the polygon, so set clip path for painter
- p->save();
QPainterPath clipPath;
clipPath.addPolygon( points );
@@ -236,11 +238,8 @@ void QgsSimpleLineSymbolLayerV2::renderPolygonOutline( const QPolygonF& points,
renderPolyline( ring, context );
- if ( mDrawInsidePolygon )
- //restore painter to reset clip path
- p->restore();
+ //restore painter's composition mode and reset clip path
+ p->restore();
@@ -252,6 +251,9 @@ void QgsSimpleLineSymbolLayerV2::renderPolyline( const QPolygonF& points, QgsSym
return;
+ p->save();
double offset = 0.0;
applyDataDefinedSymbology( context, mPen, mSelPen, offset );
@@ -280,6 +282,8 @@ void QgsSimpleLineSymbolLayerV2::renderPolyline( const QPolygonF& points, QgsSym
for ( int part = 0; part < mline.count(); ++part )
p->drawPolyline( mline[ part ] );
+ p->restore();
QgsStringMap QgsSimpleLineSymbolLayerV2::properties() const
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140827/581679c2/attachment-0001.pgp>
