[Qgis-developer] qgis server can't enable logging
kimaidou
kimaidou at gmail.com
Fri Aug 29 07:31:20 PDT 2014
I tried to use this environnement variable as well, but I cannot set the
log file as /var/log/apache2/QGIS_Server.log , even if I chmod and chown it
to give Apache full rights :
ls -lh /var/log/apache2/QGIS_Server.log
-rwxrwxrwx 1 www-data www-data 0 août 29 15:49
If I set the file to /tmp/QGIS_Server.log with
FcgidInitialEnv QGIS_SERVER_LOG_FILE "/tmp/QGIS_Server.log"
then it works correctly and the log file is filled with data.
Any hint ?
Michael
2014-08-28 15:47 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 28/08/2014 12:47, Uros Preloznik ha scritto:
> > Hi,
> > Thanks Alessandro, this is working now. I was trying only with SetEnv.
> I also had to
> > set QGIS_SERVER_LOG_LEVEL, otherwise the file was empty. So this is my
> setting now
> > which is working (Apache+Fcgid):
> > FcgidInitialEnv QGIS_SERVER_LOG_FILE /var/tmp/qgislog.txt
> > FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
> > LogLevel 0 means that everything is logged, for debugging only.
> > Is someone working on documentation? This could be included for others.
> Hi Uros,
> would you mind making a pull request on
> https://github.com/qgis/QGIS-Documentation
> Thanks.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140829/52101d13/attachment-0001.html>
