[Qgis-developer] QEP: QGIS Mapserver Python Plugins
Andrea Peri aperi2007 at gmail.com
Sat Aug 30 05:53:57 PDT 2014
Hi Luca,
Thx, now I undrstand better.
You say the procedure pywps use a new temporary location for every new user.
At the end of the procedure the last action of the procedure is remove
the location.
If the procedure was killed for a timeout. No problem.
Every new use has a new location so no prblem with grass. And with a
cron procedure the older location are cleaned.
Andrea.
2014-08-30 14:37 GMT+02:00 luca.casagrande at gmail.com
<luca.casagrande at gmail.com>:
> 2014-08-30 14:17 GMT+02:00 aperi2007 <aperi2007 at gmail.com>:
>> As example:
>> if apache kill a procedure that use grass.
>> The grass is istantaneosuly killed. And this mean it leave a lock file in a
>> own folder.
>> If an user don't remove it (the file) the grass don't restart correctly.
>> A.
> Hello Andrea,
> PyWPS can be configured to execute a Process within a temporary
> Location.
> L.
> Qgis-developer mailing list
Andrea Peri
qwerty àèìòù
