[Qgis-developer] Questions about Dialog for Select by Expression
Junior Delaz
delazj at gmail.com
Mon Dec 1 03:30:16 PST 2014
Hi All
Lene,
The height of the expression frame should indeed have a minimum value, to
avoid closing it. But this is not a new behaviour. In QGIS 2.4, you could
already close totally this frame if you drag down enough. I think it's a
bug and you can fill a ticket unless it's an intended behaviour (and it
would be nice if the dev can explain why such choice - thanks).
About syntax coloring, I have it work as expected here but I'm on 2.6.1
(haven't tried 2.6.0). Maybe, it's already fixed or it's an OS issue (I'm
on Windows 7 64bits, Osgeo4w advanced install).
For the last one, I agree with you, we should have kept "load unique
values" and "All" instead of "load values" and "All unique". The first one
seems more comprehensive to me and everybody gets that the "unique" term
applies for "All" and "10 samples". It may be confusing now, having
"unique" only on "All" button. No?
2014-11-30 9:30 GMT+01:00 Lene Fischer <lfi at ign.ku.dk>:
> Hi,
> In the dialog Select by expression there has been some changes in 2.6
> Window dragging in expressions must have a minimum vale so the express
> doesn’t disappear if you drag down.
> Secondly – before there was a syntax coloring – now it´s all the same
> color.
> At last – why does buttons change name – if there is no change in
> function? Here I refere to Load values.
> Please see the video http://screencast.com/t/VE4PvkT1 that explains the
> questions.
> Regards
> *Lene Fischer*
> Associate Professor
> *Department of Geosciences and Natural Resource Management*
> University of Copenhagen
> MOB +45 40115084
> lfi at ign.ku.dk
> [image: SCIENCE_bomaerke_UK]
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141201/5b6109dc/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141201/5b6109dc/attachment-0001.jpg>
