[Qgis-developer] QGIS slow startup on windows
Martin Dobias wonder.sk at gmail.com
Thu Dec 11 04:17:06 PST 2014
Hi
the screenshot points to reading of QGIS configuration with Qt
routines - then it gets stuck in OS kernel waiting for some kind of
lock. No idea what exactly is going wrong.
Normally the configuration on windows is stored in registry, but the
--configpath option overrides it and uses an .ini file stored in the
given directory. Is that directory actually writable - can you create
files in it? can you see an .ini file there with QGIS configuration?
Again, first try running QGIS without --configpath
Cheers
Martin
On Thu, Dec 11, 2014 at 6:22 PM, Régis Haubourg
<regis.haubourg at eau-adour-garonne.fr> wrote:
> Full monitor logs and events properties are uploaded here [0]. See first
> event properties for one failed event here [1] and a screen capture (more
> readable) here [2]
> [0] https://drive.google.com/open?id=0BzatQbprJ-hjTVFRYWUwS2tpSDQ&authuser=0
> [1]
> https://drive.google.com/open?id=1BsfWFzSkAVSDXtVZxvr-JPbPtxeVdWeo8UJv9NT_xMQ&authuser=0
> [2] https://drive.google.com/open?id=0BzatQbprJ-hjQjAzamZPSk1OWjg&authuser=0
> Thanks for your help guys
> Régis
> View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-slow-startup-on-windows-tp5177403p5177412.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
