[Qgis-developer] EPSG codes
Trevor Wiens tsw.web at gmail.com
Sat Dec 13 08:31:52 PST 2014
I did check the code for crssync and it appears that only the gdal csv and
wkt files are what is checked. This makes the situation on my machines
confusing as the reference to ESPG:6148 is absent from the gdal 1.9 and yet
it is present in the srs.db on the same machine. How it got there is
baffling, but this would appear to be a distribution issue.
TSW
On Fri, Dec 12, 2014 at 11:29 PM, Trevor Wiens <tsw.web at gmail.com> wrote:
> I don't understand it either; I'm not in any way suggesting it makes
> sense. I'm simply describing how it is.
> The confusing state of my machines suggests that crssync may do other
> things than just use the GDAL sources to populate srs.db. Is that mistaken?
> I haven't looked at the source for crssync; do you know for certain that it
> only scans the gdal csv files?
> The point the original question poster made and which I verified was that
> with QGIS 2.4 on Linux, EPSG:6148 was present and supported; an upgrade to
> 2.6.1 removes it. I don't how or why. Again, my machines suggests that this
> is more than a GDAL library issue.
> TSW
> On Fri, Dec 12, 2014 at 10:52 PM, Andre Joost <andre+joost at nurfuerspam.de>
> wrote:
>> Am 12.12.2014 um 22:14 schrieb Trevor Wiens:
>>> Andre I believe you misunderstood what I'm saying. The version of gdal
>>> does
>>> not appear to affect the presence of EPSG:6148 in srs.db
>>> Box 1:
>>> debian wheezy
>>> QGIS 2.4
>>> gdal 1.9
>>> ESPG:6148 in the srs.db
>>> ESPG6148 NOT in gdal csv files
>>> Box 2:
>>> debian wheezy
>>> QGIS 2.6.1
>>> gdal 1.9
>>> ESPG:6148 NOT in srs.db
>>> ESPG:6148 NOT in gdal csv files
>>> This issue is clearly more complex than the gdal version.
>> I don't understand your logic. Both Boxes have gdal 1.9, both missing
>> EPSG:6148. It is crssync that pushes the GDAL definition into srs.db.
>> Looking at the Windows installations of gisinternals and QGIS standalone,
>> I find the EPSG code inserted between
>> GDAL 1.10.1 and 1.11.0, published 05/2013 vs 04/2014
>> QGIS 2.2.0 and 2.4.0, published 02/2014 vs 06/2014
>> QGIS Linux packages don't include gdal, so it is up to you to get the
>> recent GDAL version (unless it is updated as dependency).
>> Greetings,
>> André Joost
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Trevor Wiens
> Apropos Information Systems
> aproposinfosystems.com
> Calgary, Alberta
> Ph. 403-973-5901
> Fax 780-666-4580
Trevor Wiens
Calgary, Alberta
Ph. 403-973-5901
Fax 780-666-4580
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141213/8049d9c4/attachment.html>
