[Qgis-developer] map-filtered legend and possible memory error in composer
Sandro Santilli
strk at keybit.net
Sat Dec 13 12:20:05 PST 2014
I'm taking a code tour in preparation to a QEP about adding map-dependent
legends support in QGIS (see http://hub.qgis.org/issues/11859).
While looking around I found that the composer code contains something
that looks like aiming at the same thing, that is:
QgsComposerLegend::updateFilterByMap()
... passes the map settings to the QgsLayerTreeModel via:
void setLegendFilterByMap( const QgsMapSettings* settings );
Further, I saw that the application supposedly has a setting for that
in the project file:
<Legend>
<filterByMap type="bool">true</filterByMap>
</Legend>
but I haven't found a way to set that graphically, does anyone know
where I set it ?
I've looked in Project Properties and in Settings->Options
--strk;
() ASCII ribbon campaign -- Keep it simple !
/\ http://strk.keybit.net/rants/ascii_mails.txt
