[Qgis-developer] Snapping tolerance
Zoltan Szecsei
zoltans at geograph.co.za
Sun Dec 14 06:12:31 PST 2014
On 2014/12/14 15:20, Rouzaud Denis wrote:
> From my point of view, the settings of snapping are far too advanced
> for 95% of the usage. Let’s not make them even more complicated, just
> for a very specific use case.
Hi Denis,
I have to disagree with you, as someone who does a fair amount of
digitising.
To support Ramon, I too work with many map layers in many different
projections, so we mustn't lose facilities that we (even by accident) have.
Some points:
* Being able to set a global tolerance in linear units, and have QGIS
convert that to the relevant layer CRS would be VERY useful.
ie: I want a 10m snapping tolerance even if I am on a LatLong map layer.
* QGIS only allows Snap Modes "To Vertex", "To Segment" or "To Vertex
and Segment"
What if both a Line-end and a Vertex on that same line is within
tolerance?
We really need to differentiate between Point (the Start & End
Vertex of a Line or Polygon), Vertex and Segment AND be able to set
the Snapping order between those three components of a graphical entity.
* The snapping order between layers is currently set to the order of
the maps in your Layer Tree. Depending on the features you are
digitising, this is not optimal as one often needs to have a layer
snapping order different from the viewing order.
* It would be useful to set the layer snapping order in the Snapping
Options table, and have the _option_ (and not enforced by the
developer) to prioritise the current map being edited.
* If I remember correctly, snapping returns a position from the first
layer it finds anything in, and IIRC if there are multiple snaps on
that layer, the closest is returned? What if there are still
unsearched layers that might have something within tolerance?
The above is just a couple of walls I have hit when trying to digitise
large volume jobs with multiple feature types and map layers.
My 2c
Regards,
Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
GIS and Photogrammetric Services
P.O. Box 7, Muizenberg 7950, South Africa.
Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141214/9bba23a9/attachment.html>
