[Qgis-developer] Moving a layer with PyQGIS using the new layer tree
Germán Carrillo
carrillo.german at gmail.com
Wed Dec 17 13:05:49 PST 2014
Hi all (and Martin D.),
I've been trying to reproduce the instructions given here [1] for moving
layers. It seems that the code doesn't work if the layer to be moved is
inside a group.
Specifically, trying to move a layer that is inside a group, I can add the
clonned layer to the layer tree but I cannot get the original layer
removed, i.e., the following command doesn't work:
root.removeChildNode( originalLayer )
It doesn't throw any message nor change the map/ToC status.
Can you reproduce the problem? I'm using QGIS 2.6.1 on Ubuntu.
Regards,
Germán Carrillo
[1]
http://www.lutraconsulting.co.uk/blog/2014/07/25/qgis-layer-tree-api-part-2/
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://geotux.tuxfamily.org/
http://twitter.com/GeoTux2
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141217/80dbb4ac/attachment.html>
