On Thu, Dec 18, 2014 at 10:09 AM, René-Luc Dhont <rldhont at gmail.com> wrote: > Hi luca, > > Which QGIS version do you use ? master, 2.6 or 2.4 ? Maybe I've found a bug: if the project contains ONLY embedded layers, it returns 500 error. I've added a non-embedded layer, and it worked. should I file a bug?
