[Qgis-developer] Moving a layer with PyQGIS using the new layer tree
Martin Dobias
wonder.sk at gmail.com
Sun Dec 21 05:55:08 PST 2014
Hi
On Thu, Dec 18, 2014 at 9:50 PM, Germán Carrillo <carrillo.german at gmail.com>
wrote:
> Thank you Luigi.
> So, I guess the following code would be enough to make the example given
> in [1] much more generic:
> cloned_group1 = node_group1.clone()
> root.insertChildNode(0, cloned_group1)
> parent = node_group1.parent() # new code
> parent.removeChildNode(node_group1) # replace root by parent
Luigi is right - you need to call removeChildNode() on the parent node.
When I will find some time I will add a note to the example.
Cheers
Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141221/7d77ba29/attachment.html>
