[Qgis-developer] Can qgis be started with python disabled ?
Geo DrinX geodrinx at gmail.com
Sun Dec 21 14:33:27 PST 2014
2014-12-21 15:12 GMT+01:00 Martin Dobias <wonder.sk at gmail.com>:
> On Wed, Dec 17, 2014 at 1:30 AM, Sandro Santilli <strk at keybit.net> wrote:
>> Can I start qgis with no python support even if it is compiled in ?
>> I'd use it to reduce load while running under valgrind...
>> To the same extent, can it be started with no plugins from an environment
>> variable or similar?
> A bit more hard-core, but you can e.g. rename libqgispython.so to
> something else - it is loaded on demand and if the load fails QGIS will
> just run without python.
Good info.   So we can use it to discover finally if plugins are
responsible of QGIS 2.6 crashes.
Thank you
Roberto
> Cheers
> Martin
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141221/066b63d5/attachment.html>
