[Qgis-developer] Wrong $length
Paolo Cavallini cavallini at faunalia.it
Wed Dec 24 05:37:04 PST 2014
Hi all.
The calculation of $length on the attached file returns weird results:
when calculated as virtual field is ok, whereas when updating an
existing field a negative result is given. I assume this is related to
topological errors in the line, but nevertheless the diff between the
two methods is unexpected.
Furthermore, "Update all" does not seem to work on a column where
sorting is applied (by clicking on column head).
Anyone confirms? Should I open two tickets?
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
Type: application/gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141224/f23e57a1/attachment.bin>
