[Qgis-developer] Compilation qgis2.7.0 with VS2010 and Qt 5.3.2
Anatoliy Golubev
darth.naihil at gmail.com
Wed Dec 24 05:52:41 PST 2014
Hi Matthias! Thanks for reply!
I know that Qt5 support was merged recently and want to test it.
Before PR#1743 there were errors with linux-specific includes, such as
netinet/in.h.
Im compile qwt, qwtpolar and qscintilla with Qt5.
It may be CMake rules that generate improper configuration for Qt5
windows build, coz compilation with Qt4 with same environment works
fine.
2014-12-23 18:22 GMT+03:00 Matthias Kuhn <matthias.kuhn at gmx.ch>:
> Hi Anatoliy,
> Does that mean that it worked fine before PR #1743?
> In general Qt5 support is still pretty new and did not receive much
> testing. I don't know how many people have run such a setup on Windows.
> It requires to also link dependencies like qwt, qwtpolar and qscintilla
> against Qt5.
> That said, it is very welcome if people test and improve Qt5 support.
> But if you want to stay out of the way of problems you are better off if
> you stick to the well-tested Qt4.
> Anyway, the problem you have here looks like a linker problem to the
> MSVCRT, so Windows specific and not Qt5 specific. As I seldom use
> Windows I can't offer more help than this hint, sorry.
> Regards,
> Matthias
