[Qgis-developer] Wrong $length
Paolo Cavallini cavallini at faunalia.it
Wed Dec 24 10:04:07 PST 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 24/12/2014 18:26, Werner Macho ha scritto:
> Hi Paolo! I confirm the behavior with negative and positive value.
> But I also expired some kind of infinite loop when updating
> existing or creating new (not virtual) field. Seem to be some kind
> of error when _not_ using virtual field. Which is the correct
> length? Do you know? Probably both results are wrong (which would
> be ok if the line has an error inside anyway, but in that case it
> should also throw an error to a popup window).
Hi Werner,
thanks for help. Further tests, more puzzling results:
* contrary to expectations, GRASS v.clean does not lean up the vector
* the length in the virtual field appears correct
* cleaning up the vector by hand (removing duplicates) does not change
the results
* the topology checker plugin does not find topo errors, nor
duplicates, in both layers (the original and the cleaned up).
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iEYEARECAAYFAlSbABYACgkQ/NedwLUzIr5dTACfYH8Y/6euUpmmf/C75kLhjbO9
n4wAn1UD3BoZdrzWCREQKIaDElrMvTOG
=8iCd
-----END PGP SIGNATURE-----
