[Qgis-developer] Problem inserting a new version of plugin
Werner Macho
werner.macho at gmail.com
Mon Dec 29 02:19:52 PST 2014
Glad that it worked!
Happy new year to you too!
regards
Werner
On Mon, Dec 29, 2014 at 11:15 AM, Geo DrinX <geodrinx at gmail.com> wrote:
> Great ! You have right ! I dropped all spaces around the "=" and it
> works !!!
> Thank you Werner ! And Happy New Year !!!!
> Roberto
> 2014-12-29 11:07 GMT+01:00 Werner Macho <werner.macho at gmail.com>:
>> Hi!
>> I had a short look into my plugin and found
>> experimental=True
>> I am not sure but probably its the space in front and after the = sign?
>> I guess it's worth a try ;)
>> regards
>> Werner
>> On Mon, Dec 29, 2014 at 11:02 AM, Geo DrinX <geodrinx at gmail.com> wrote:
>> > Hello,
>> > I am trying to insert a new version of "rasmover" plugin, but I had
>> > errors
>> > from the page:
>> > http://plugins.qgis.org/plugins/rasmover/version/add/
>> > This is the ZIP that I am inserting:
>> > https://github.com/geodrinx/rasmover/archive/master.zip
>> > The error I receive is:
>> > "There wer errors reading plugin package (please check also your
>> > plugin's
>> > metadata).
>> > The 'experimental' flag in the form does not match the 'experimental'
>> > flag
>> > in the plugin package metadata' "
>> > and then (also after set the experiemntal flag) I had:
>> > "This field is required"
>> > without other indication.
>> > Could someone help me ?
>> > Thank you
>> > Roberto
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
