[Qgis-developer] QGIS SZIP.DLL Licensing?
Etienne Tourigny etourigny.dev at gmail.com
Mon Feb 3 10:59:50 PST 2014
What is the problem with distributing the szip.dll ? There is no agreement
between qgis (or gdal) with szip/hdf group.
My understanding of the info in this page
http://www.hdfgroup.org/doc_resource/SZIP/ is:
- In no circumstances a user can create hdf5 files with szip encoding
within qgis. So far, only gtiff files are created within qgis.
- you are correct in stating that commercial products can use szip for
decoding only, so it is OK for qgis to distribute the szip library.
- as qgis is not a commercial product and does not allow to create
szip-encoded hdf5 files, there is no need for any commercial licence.
- if someone were to write software, based on qgis (and gdal), which sould
create an szip-encoded hdf5 file, that entity would require a commercial
licence
There is no GPL szip library, AFAIK.
On Mon, Feb 3, 2014 at 3:15 PM, Moriarty, Mark F
<mark.f.moriarty at lmco.com>wrote:
>  Does QGIS have any license agreement related to SZIP use?
> I'd like to use QGIS on a project, but we're stuck on whether/how the
> szip.dll is licensed for use.
> For example HDF specifically has a license page asserting permission to
> use szip in their distribution, so long as it is used within the context of
> their overall app.  For a commercial firm, the permission is just to
> decode, not to encode, but that is fine.
> I tried just deleting/renaming the szip.dll, since we do not actually need
> the functionality for our use, but it appears to be tightly bound to the
> build - qgis errors-out if it does not detect a proper, functioning,
> szip.dll on startup.
> If there isn't a license statement from the intellectual property owner
> allowing its use/distribution to decode with qgis, is it possible to
> include a user-controllable switch to allow not including it, or to perhaps
> include a true GPL zip package, albeit losing the lossless functionality?
> Thanks.
> Mark
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140203/286455f9/attachment.html>
