[Qgis-developer] [postgis-users] RE : QGis 2.0 Copy/Paste from shapefile to Postgis issue if the primary key is a string
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Feb 4 01:50:59 PST 2014
Here is the reply concerning copy/pase with primary keys on postgis.
Jürgen, can you comment this?
Thanks,
Denis
On 03. 02. 14 09:40, F T wrote:
> Hi,
> QGis should not deal with Postgre SQl explicit primary keys.
> It is postgreSQL to manage the explicit primary key.
> With Qgis 1.7.4, copy/paste with explicit primary keys where ok
> If QGis 1.7.4 sends a unique primary key, PostgreSQL accept it, if the explicit key is not unique, it reject it.
> QGis 2.0 brings a regression, it put all the primary keys to null...
> Denis 's workaround to add a serial to the table and a constraint (unique not null) to the explicit primary key is not a solution for us.
> We have a lots of tables that are used not only with QGis...
> Changing all the tables just because QGis 2.0 needs a non-standard feature is a pain.
> And QGis 1.7.4 was doing this copy/paste job fine.
> However, this is a QGis 2.0 pb and not a postgis pb.
> I will continue on the QGis List
> Thanks
> Fabrice
> Hi,
> QGIS prevent to overwrite the primary key field when it copies/pastes,
> this is why it leaves the field empty.
> One way would be to add the constraint after the copy/paste if it's for
> a single shot.
> Otherwise, just add a unique constraint on f1 and add a serial as
> primary key.
> Cheers,
> Denis
> On 31. 01. 14 15:02, F T wrote:
> >/ Hello
> />/ We have a pb with copy/paste from a shapefile to postgis if the
> />/ primary key is a string.
> />/ The primary key is left NULL and no commit is possible.
> />/ To reproduce the pb :
> />/ Create *table1 *with a string primary key
> />/ CREATE TABLE table1
> />/ f1 character varying(10) NOT NULL,
> />/ f2 character varying(10),
> />/ geom geometry,
> />/ *CONSTRAINT t1_pkey PRIMARY KEY (f1),*
> />/ CONSTRAINT enforce_dims_geom CHECK (st_ndims(geom) = 2),
> />/ CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) =
> />/ 'POINT'::text),
> />/ CONSTRAINT enforce_srid_geom CHECK (st_srid(geom) = 2154)
> />/ *table2* is the same as table 1 but it has no primary key
> />/ CREATE TABLE table2
> />/ geom geometry,
> />/ 'POINT'::text),
> />/ *shapes.shp* is a shapefile that contains the points I would like to
> />/ copy/paste in the Postgis tables
> />/ (see attached zip file)
> />/ 1) if I copy/paste the points from shapes.shp to table1, the key field
> />/ stays NULL and the commit is impossible.
> />/ 2) if I copy/paste the points from shapes.shp to table2, everything is ok.
> />/ Have you ever seen this bug?
> />/ Thanks
> />/ Fabrice/
> postgis-users mailing list
> postgis-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140204/549d2b03/attachment-0001.html>
