[Qgis-developer] some flaw in RDP algorithm?
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Feb 5 04:15:54 PST 2014
Hi Giuliano,
> you're probably right, but I have never advised to develop a new
> simplification algorithm :-)
> I am a "mathematical" as a hobby, I have only met a "little problem"
> with the RDP algorithm and I reported it, and I had fun writing an
> algorithm for fun but no idea of proposing developments in this
> direction;
> Ah, I missed that. If it's a new algorithm, maybe try and get it published
into a journal? Then other math types who are into that sort of thing (and
more importantly, understand it! :-) ) can give you feedback on it. As you
may know, there's quite a bit of literature on
generalisation/simplification algorithms, including for RDP -
http://scholar.google.co.uk/scholar?q=rdp+simplification - you may find
some of that interesting reading.
Kind Regards,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140205/adbd3eb5/attachment.html>
