[Qgis-developer] Error in compilation
Larry Shaffer larrys at dakotacarto.com
Fri Feb 7 12:08:39 PST 2014
On Fri, Feb 7, 2014 at 1:02 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Fri, Feb 07, 2014 at 08:03:54PM +0100, Paolo Cavallini wrote:
> > Compiling current master throws an error here.
> > A local problem, or is someone confirming?
> It fails for me too, but not sure it's the same error
> ( your log doesn't contain the error line )
> Here's my error:
> In file included from /usr/src/qgis/qgis-master/src/app/qgsoptions.h:22:0,
>                  from /usr/src/qgis/qgis-master/src/app/qgisapp.cpp:156:
> /usr/src/qgis/build/master/src/app/../ui/ui_qgsoptionsbase.h:43:20: fatal
> error: qgis.gui: No such file or directory
>  #include "qgis.gui"
> compilation terminated.
Sandro, that error should be fixed in
https://github.com/qgis/QGIS/commit/1bf33b5
Regards,
Larry
> --strk;
> > Any hint will be appreciated.
> > Thanks.
> > [ 53%] Built target spatialiteprovider
> > Linking CXX shared module
> ../../../output/lib/qgis/plugins/libpostgresprovider.so
> > cd /usr/local/src/qgis/QGIS/debian/build/src/providers/postgres &&
> /usr/bin/cmake -E
> > cmake_link_script CMakeFiles/postgresprovider.dir/link.txt --verbose=YES
> > /usr/bin/c++  -fPIC -g -O2 -fstack-protector --param=ssp-buffer-size=4
> -Wformat
> > - -Werror=format-security -D_FORTIFY_SOURCE=2 -O2  -Wall -Wextra
> -Wno-long-long
> > - -Wformat-security -Wno-strict-aliasing  -Wl,-z,relro
> -Wl,--no-undefined -shared
> > - -Wl,-soname,libpostgresprovider.so -o
> > CMakeFiles/postgresprovider.dir/qgspostgresprovider.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspostgresconn.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspostgresdataitems.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspostgresfeatureiterator.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspgsourceselect.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspgnewconnection.cpp.o
> > CMakeFiles/postgresprovider.dir/qgspgtablemodel.cpp.o
> > CMakeFiles/postgresprovider.dir/qgscolumntypethread.cpp.o
> > CMakeFiles/postgresprovider.dir/moc_qgspostgresprovider.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgspostgresconn.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgspostgresdataitems.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgspgsourceselect.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgspgnewconnection.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgspgtablemodel.cxx.o
> > CMakeFiles/postgresprovider.dir/moc_qgscolumntypethread.cxx.o
> > - -L/usr/local/src/qgis/QGIS/debian/build/src/core
> > - -L/usr/local/src/qgis/QGIS/debian/build/src/gui -lpq
> > ../../../output/lib/libqgis_core.so.2.1.0
> ../../../output/lib/libqgis_gui.so.2.1.0
> > ../../../output/lib/libqgis_core.so.2.1.0 -lQtXml -lQtCore -lQtGui
> -lQtNetwork
> > - -lQtSvg -lQtWebKit -lproj -lgeos_c -lgdal -lspatialindex -lexpat
> -lsqlite3
> > - -lspatialite -Wl,-Bstatic -lQtUiTools -Wl,-Bdynamic -lqwt
> -Wl,-rpath,/usr/local/src/qgis/QGIS/debian/build/src/core:/usr/local/src/qgis/QGIS/debian/build/src/gui:/usr/local/src/qgis/QGIS/debian/build/output/lib:
> > make[3]: Leaving directory `/usr/local/src/qgis/QGIS/debian/build'
> > /usr/bin/cmake -E cmake_progress_report
> > /usr/local/src/qgis/QGIS/debian/build/CMakeFiles  17
> > [ 53%] Built target postgresprovider
> > make[2]: Leaving directory `/usr/local/src/qgis/QGIS/debian/build'
> > make[1]: *** [all] Error 2
> > make[1]: Leaving directory `/usr/local/src/qgis/QGIS/debian/build'
> > make: *** [build-stamp] Error 2
> > dpkg-buildpackage: error: debian/rules build gave error exit status 2
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140207/1f37ffb6/attachment.html>
