[Qgis-developer] "Spline" plugin bug on QGis 2.0.1 64 bit Windows
Radim Blazek
radim.blazek at gmail.com
Sat Feb 8 09:26:57 PST 2014
On Fri, Feb 7, 2014 at 5:11 PM, Geo DrinX <geodrinx at gmail.com> wrote:
> Hello all,
> as in object, something other had my same error, closing a spline path ?
> Traceback (most recent call last):
> File "C:\Users\rrr/.qgis2/python/plugins\spline\spline.py", line 97, in
> canvasPressEvent
> self.createFeature()
> File "C:\Users\rrr/.qgis2/python/plugins\spline\spline.py", line 145, in
> createFeature
> if dlg.exec_():
> AttributeError: 'NoneType' object has no attribute 'exec_'
It means that iface.getFeatureForm(layer, f) returned None, that
should not usually happen.
Can you try to select a vector layer and run from python shell:
layer = iface.mapCanvas().currentLayer()
f = QgsFeature(layer.pendingFields())
dlg = iface.getFeatureForm(layer, f)
dlg.exec_()
Radim
> Versione Python:
> 2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
> Thank you for any info about it
> Roberto
> Qgis-developer mailing list
