[Qgis-developer] Custom "Identify Results" Window
Josua S
josh-talk at hotmail.com
Mon Feb 10 05:49:11 PST 2014
Hello Matthias
Thank you very much for your quick answer! I have a question left: Is it possible to inherit the identify maptool and use it only using Python? Or does this have to be done in C++?
Josua
> Date: Mon, 10 Feb 2014 14:39:59 +0100
> From: matthias.kuhn at gmx.ch
> To: josh-talk at hotmail.com
> CC: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Custom "Identify Results" Window
> Hi Josua,
> I don't think the possibility is available OOTB yet, but it should be
> straightforward to create your own maptool which inherits from the
> identify maptool and uses a QgsDualView with a request (or filter)
> limiting the available features to only the relevant feature ids. This
> should get you a list of all features and their form when selected.
> Would be nice to be see this in core as well in the future.
> Best
> Matthias
> On Mon 10 Feb 2014 02:29:37 PM CET, Josua S wrote:
>> Hello
>> I am working on a QGIS Plugin with a touch-optimized GUI. So it is actually very useful to be able to create custom feature forms. However if I use the Identify tool and there are two or more features near together, QGIS does not show my feature form but a "Identify Results" window containing all the features nearby. So my question is: Is there a possibility to create a custom "Identify Results" window with Python if there are several features? Or is there a setting to change its behavior? Thank you very much for your help.
>> Josua
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
