[Qgis-developer] Oracle layers - improving the speed
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Feb 10 07:56:17 PST 2014
Hey Jürgen,
> There's always an extent, but that not necessarily reflect an actual bbox,
> but
> just sets the available bounds, which are often set much bigger than the
> actual
> data. But the bounding box is determined after insertion of the layer
> anyway.
Fair point, but for us it's definitely still preferable over having QGIS
"hang" for several minutes waiting for Oracle to perform a MBR check on a
table with millions of features.
> To insert the layer we just need tablename, column, type and srid - and
> that's
> what the thread searches for.
How about doing the search for "type" when the layer is actually added to
QGIS? It could also confirm the other stuff (which it got from metadata) at
that time too.
> An additional idea would be to use the filters upfront. Currently you can
> only
> filter the result of the layer search after the search has already been
> run.
> Instead we could reduce the searches we want by just looking for tables
> with
> given (partial) name, in a given schema, srid and/or geometry type.
> Especially
> in cases where the search is expensive, because there are loads of tables,
> this
> is would even be useful if performance wasn't an issue.
> And that would also be interesting for all other database providers.
Oooh, I like that idea!
Kind regards,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140210/7d9d80dd/attachment.html>
