[Qgis-developer] Atlas preview
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Feb 12 05:44:43 PST 2014
I don't have any trouble using the preview, no idea where the problem
comes from.
You don't have any filter set in it?
Concerning the main canvas, there is a bug if you check "hidden coverage
layer", see #9506. Nyall should fix it for 2.2
http://hub.qgis.org/issues/9506
On 12. 02. 14 14:35, Paolo Cavallini wrote:
> Il 12/02/2014 14:28, Denis Rouzaud ha scritto:
>> Hi Paolo,
>> Is your map in render mode (not cache)?
> Hi Denis,
> It was on Cache, switched to Render, no change.
> BTW, it seems to interact with the main canvas, preventing the display
> of the layer used for Atlas.
> Merci.
