[Qgis-developer] how to use QgsPalLayerSettings class
Yang xmayyang at gmail.com
Wed Feb 12 18:56:03 PST 2014
I'm a newer of qgis
I write a C++ application.
I want to set a layer's label when it smaller than 1.00mm will be not
visible.
My code is as follows:
void LayerMgr::showLabels(QgsVectorLayer *layer, bool opt)
     int index = 0;
     QString attrName = "name";
     QgsPalLayerSettings  labelSetting;
     QgsLabel *layerLabel = layer->label();
     QgsFields field = layer->dataProvider()->fields();
     if (false == opt)
         layer->enableLabels(false);
         return;
     for (index = 0; index < field.size(); index++)
         if (QString(field[index].name()) == attrName)
             break;
     labelSetting.enabled = true;
     labelSetting.fieldName = QString(field[index].name());
     labelSetting.textColor = Qt::black;
     labelSetting.minFeatureSize = 10.0;
     labelSetting.writeToLayer(layer);
     mpMapCanvas->refresh();
But it was not usful.Who can help me.
Thank you very much.
