[Qgis-developer] QgsRubberBand RuntimeError: underlying C/C++ object has been deleted
Radim Blazek
radim.blazek at gmail.com
Wed Feb 12 23:35:33 PST 2014
On Thu, Feb 13, 2014 at 7:13 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Hi Radim,
> Can you show us the whole code?
https://github.com/blazek/spline/blob/master/spline/spline.py
Radim
> Cheers,
> Denis
> On 12. 02. 14 19:17, Radim Blazek wrote:
>> On Wed, Feb 12, 2014 at 2:50 PM, Martin Dobias <wonder.sk at gmail.com>
>> wrote:
>>> Hi Radim
>>> On Wed, Feb 12, 2014 at 8:03 PM, Radim Blazek <radim.blazek at gmail.com>
>>> wrote:
>>>> On Wed, Feb 12, 2014 at 1:45 PM, Radim Blazek <radim.blazek at gmail.com>
>>>> wrote:
>>>>> I am using rubber band in Python plugin:
>>>>> self.rb = QgsRubberBand(self.canvas, QGis.Polygon)
>>>>> and on mouse move
>>>>> self.rb.addPoint( point, update )
>>>>> It works well on most systems only for Win7/32bit (QGIS 2.0.1, Python
>>>>> 2.7.4) it was reported that it fails with "RuntimeError: underlying
>>>>> C/C++ object has been deleted"
>>> When does it report the error - when closing QGIS?
>> I don't know but I presume when map tool is used, it is called from
>> QgsMapTool::canvasMoveEvent().
>> Radim
>>>>> I see that ownership of rubber band is passed to map canvas
>>>>> QgsRubberBand( QgsMapCanvas* mapCanvas /TransferThis/,
>>>>> QGis::GeometryType geometryType = QGis::Line );
>>>>> that is OK, but QgsMapCanvas should not delete QGraphicsItem until it
>>>>> is destructed.
>>>>> So how can the QgsRubberBand be deleted before QGIS is closed?
>>>> BTW, because true owner of QGraphicsItem is QGraphicsScene, should not
>>>> we first mScene->removeItem() (which returns ownership) before item is
>>>> deleted in QgsMapCanvas destructor?
>>> That's the correct approach in Python (IIRC). You can remove the item
>>> in your map tool's deactivate() method.
>>> Regards
>>> Martin
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
