[Qgis-developer] QgsRubberBand RuntimeError: underlying C/C++ object has been deleted
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Feb 13 00:04:39 PST 2014
Hi Radim,
It seems it is your point that has been deleted, not the rubber band.
Doing "print point" before addPoint crashes.
Cheers,
Denis
On 13. 02. 14 08:39, Radim Blazek wrote:
> On Thu, Feb 13, 2014 at 8:35 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>> On Thu, Feb 13, 2014 at 7:13 AM, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
>>> Hi Radim,
>>> Can you show us the whole code?
>> https://github.com/blazek/spline/blob/master/spline/spline.py
> And traceback:
> Traceback (most recent call last):
> File "C:\Users\user1/.qgis2/python/plugins\spline\spline.py", line
> 174, in canvasMoveEvent
> self.setRubberBandPoints(points )
> 207, in setRubberBandPoints
> self.rb.addPoint( point, update )
> Radim
>> Radim
>>> Cheers,
>>> Denis
>>> On 12. 02. 14 19:17, Radim Blazek wrote:
>>>> On Wed, Feb 12, 2014 at 2:50 PM, Martin Dobias <wonder.sk at gmail.com>
>>>> wrote:
>>>>> Hi Radim
>>>>> On Wed, Feb 12, 2014 at 8:03 PM, Radim Blazek <radim.blazek at gmail.com>
>>>>> wrote:
>>>>>> On Wed, Feb 12, 2014 at 1:45 PM, Radim Blazek <radim.blazek at gmail.com>
>>>>>> wrote:
>>>>>>> I am using rubber band in Python plugin:
>>>>>>> self.rb = QgsRubberBand(self.canvas, QGis.Polygon)
>>>>>>> and on mouse move
>>>>>>> It works well on most systems only for Win7/32bit (QGIS 2.0.1, Python
>>>>>>> 2.7.4) it was reported that it fails with "RuntimeError: underlying
>>>>>>> C/C++ object has been deleted"
>>>>> When does it report the error - when closing QGIS?
>>>> I don't know but I presume when map tool is used, it is called from
>>>> QgsMapTool::canvasMoveEvent().
>>>> Radim
>>>>>>> I see that ownership of rubber band is passed to map canvas
>>>>>>> QgsRubberBand( QgsMapCanvas* mapCanvas /TransferThis/,
>>>>>>> QGis::GeometryType geometryType = QGis::Line );
>>>>>>> that is OK, but QgsMapCanvas should not delete QGraphicsItem until it
>>>>>>> is destructed.
>>>>>>> So how can the QgsRubberBand be deleted before QGIS is closed?
>>>>>> BTW, because true owner of QGraphicsItem is QGraphicsScene, should not
>>>>>> we first mScene->removeItem() (which returns ownership) before item is
>>>>>> deleted in QgsMapCanvas destructor?
>>>>> That's the correct approach in Python (IIRC). You can remove the item
>>>>> in your map tool's deactivate() method.
>>>>> Regards
>>>>> Martin
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
