[Qgis-developer] [QGIS-Server] Closing issues
rldhont
rldhont at gmail.com
Fri Feb 14 04:54:54 PST 2014
Hi dev,
* #8518 OWS tab - Abstract field of service capabilities adds additional
new lines at project save
-> I can't repeat the bug. Some one else can confirm and close the issue ?
http://hub.qgis.org/issues/8518
* #8499 OWS tab - adding CRS restrictions not reliable
-> I have opened a Pull Request. https://github.com/qgis/QGIS/pull/1063
This code can be usefull every where projection selector is used.
This code is only 5 lines.
Salvatore Larosa tested it. Can some one reviewing it ?
http://hub.qgis.org/issues/8499
* #7826 Server: composer picture does not work with relative path
? Does the issue is Operating System dependant ?
http://hub.qgis.org/issues/7826
* #7712 qgis server master does not work on Windows(?)
-> this bug has been opened 10 months ago, QGIS 2 has been published and
QGIS-Server works fine on Windows.
Does this issue can be closed ?
http://hub.qgis.org/issues/7712
Regards,
René-Luc D'Hont
3Liz
