[Qgis-developer] Metadata fields in QGIS
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Feb 18 04:18:54 PST 2014
I posted this to the user list a couple of weeks ago but no interest. Maybe
the dev list has some thoughts?
Hi List,
>   I'm wondering if anyone uses the "metadata" fields for data in QGIS
> (Layer Properties -> Metadata)? I've been told that this is supposed to be
> filled in manually.
> I ask because I originally thought it was supposed to be filled in
> automatically - http://hub.qgis.org/issues/8870 - And for OGC services
> (WMS, WFS etc) this seems logical as all of the data is in the
> GetCapabilities.
> Does anyone have a view on this? Should the metadata be filled in
> automatically or should the user enter it manually? My issue with the later
> is that I guess the metadata is only saved in a .qgs file, and not the
> source itself, so no-one else is going to be able to see manually entered
> data.
> Thoughts? Comments?
> Cheers,
> Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140218/08a842cc/attachment.html>
