[Qgis-developer] Failing tests consider blockers
Marco Hugentobler
marco.hugentobler at sourcepole.ch
Wed Feb 19 02:44:14 PST 2014
Hi
I'm voting for releasing in time as is.
We had that discussion prior to each release before. It turned out that
after shifting the release date, new must-fix bugs showed up and the
release was shifted over and over again.
With a fixed release schedule, it is no problem to wait for the next
release with bugfixes and features, because the next release comes
within a few months. If releases are delayed, people cannot rely on a
next release coming after four months.
Regards,
Marco
On 19.02.2014 11:33, Radim Blazek wrote:
> On Wed, Feb 19, 2014 at 10:53 AM, Jürgen E. <jef at norbit.de> wrote:
>> Hi Radim,
>> On Wed, 19. Feb 2014 at 09:14:43 +0100, Radim Blazek wrote:
>>> On Sun, Feb 16, 2014 at 11:41 PM, Jürgen E. <jef at norbit.de> wrote:
>>>> What I wanted to say is that there are a bunch of tests that fail because
>>>> they are not up to date or fail for other reasons that are not related to
>>>> actual bugs in qgis itself. For example render tests, which fail because of
>>>> fonts or other differences (eg. removed renderers). I think that are the
>>>> majority of tests that currently fail.
>>> Platform dependent tests (fonts) don't make sense for me and should be
>>> disabled until get fixed (e.g. using font set shipped with QGIS). Renderer
>>> test should be updated and only real bugs will remain and those should be
>>> blockers, I think.
>> Well, there are platform dependant bugs and therefore there also could be
>> platform dependant tests. But those would need to be clearly marked as such
>> and only run on the corresponding platform.
>> Do we need to discuss that failing tests - or any other bug - should be fixed?
>> I doubt that we do.
>> I'm just objecting to planing ahead too much
> Exactly, so why to insist exactly on release day planned 3 months ago?
>> - let's first fix the tests and then decide further steps.
> That won't work, we must be forced to fix them.
>>>> Another thing is that we don't have the concept of actual blockers anymore.
>>>> We release every four months what we have at that point. Blockers are just
>>>> highest priority for bugs.
>>> Blockers do not block stable release?! I don't think anything like that was
>>> ever explicitly said nor there is a general consensus about that. I read your
>>> release plan again and I only found:
>> We just have releases. The plan is to release what we have on release day. Of
>> course that should be in the best possible shape, but whatever we do it will
>> have known und unknown bugs.
> Whatever we do it will have unknown bugs but does not have to have known bugs.
> I am strongly against releasing with known blockers.
> Radim
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole - Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
