[Qgis-developer] Master doesn't compile
Martin Dobias
wonder.sk at gmail.com
Sun Feb 23 08:47:31 PST 2014
Hi Etienne
On Sun, Feb 23, 2014 at 11:33 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> Just a remark, there are quite a few new warnings (mostly about deprecated
> functions, but also some unused or variables or parameters) using gcc 4.7.3
> Here are some, in no particular order, there might be more
> /data/src/qgis/qgis-etiennesky/build-debug/src/core/moc_qgsmaplayer.cxx: In
> static member function 'static void
> QgsMapLayer::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)':
> /data/src/qgis/qgis-etiennesky/build-debug/src/core/moc_qgsmaplayer.cxx:102:38:
> warning: 'void QgsMapLayer::clearCacheImage()' is deprecated (declared at
> /data/src/qgis/qgis-etiennesky/build-debug/src/core/../../../src/core/qgsmaplayer.h:386)
> [-Wdeprecated-declarations]
Most of them are in files generated by MOC - maybe we could disable
the deprecation warnings for those files. For the actual QGIS source
code that triggers deprecation warnings, these should get sorted out.
Regards
Martin
