[Qgis-developer] Processing - bug when editing an open model ?
kimaidou
kimaidou at gmail.com
Mon Feb 24 04:20:57 PST 2014
I just opened a ticket for this bug : https://hub.qgis.org/issues/9632
2014-02-19 14:54 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> Before reporting a bug, I would like to know if it is not already
> reported. I am using QGIS 2.0.3 with Processing plugin experimental version
> 2.0-20131120 (Ubuntu)
> When I create a graphical model from scratch, everything works fine. I can
> save the model and run it.
> But whenever I try to open an existing model, then modify one of the algo
> and apply modifications with the OK button, the interface freezes
> completely. I then need to kill QGIS to get out of it which is very bad in
> case you have not saved the project...
> Has anyone reported this or should I fill a new bug ?
> Regards,
> Michael
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140224/68f35a64/attachment.html>
