[Qgis-developer] Some notes of 2.2. OpenSuse 12.3 ""release"
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Feb 26 05:54:46 PST 2014
https://build.opensuse.org/package/show/Application:Geo/qgis2
There is a "report bug" link in the above URL.
I will check it when I find some time later.
Best,
Angelos
On 02/25/2014 08:50 PM, Olivier Dalang wrote:
>> 1. Manage and Install Plugins ... -> Upgradeable ; I've two left after I
>> upgraded all others.
>> mmqgis and Qgis2threejs both tell "There is a new version available"
>   I think the problem comes from the plugin's repository XML : for my "layer
> combinations" plugins, the metadata file sets version=1.01, but the
> plugin's current version is displayed as 1.1 (both in QGIS's plugin manager
> and on http://plugins.qgis.org).
> So, the plugins stays marked as "upgradable"... I'm not sure on where to
> file tickets for that (since it's probably not in QGIS itself)
> Thanks !
> Olivier
> 2014-02-25 15:22 GMT+01:00 Kari Salovaara <kari.salovaara at pp1.inet.fi>:
>> Replied privately (due files not for public)
>> Cheers,
>> Kari
>> On 02/25/2014 02:50 PM, Angelos Tzotsos wrote:
>>> Hi,
>>> On 02/25/2014 05:04 AM, Kari Salovaara wrote:
>>>> Hi,
>>>> thanks for all developers of huge and fantastic work again.
>>>> I've OpenSuse 12.3 updated about per midnight (GMT 24.2.2014 23:00). and
>>>> qgis2-2.2.0-6.1
>>> Can you please provide a full list of repositories that you have enabled
>>> in your 12.3 environment?
>>>> I'd some notices of small "bugs". I was not able to use other machinery
>>>> so I
>>>> don't know ......
>>>> I've tried both Upgrade all and Upgrade plugin. Restarted QGIS and tried
>>>> again.
>>>> They just won't want to be upgraded.
>>> Please try to erase those plugins completely from your environment and
>>> install again from the Plugins Manager.
>>> I cannot reproduce this issue.
>>>> Then I uninstalled mmqgis and installed again. Now it has been upgraded
>>>> but is
>>>> again in the list of upgradeable. If You look the numbering where I
>>>> expect the
>>>> error lie ?
>>>> Installed version: 2014.01.06 (in /home/kari/.qgis2/python/
>>>> plugins/mmqgis)
>>>> Available version: 2014.1.6 (in QGIS Official Plugin Repository)
>>>> - and uninstall->install>result was also
>>>> Installed version: 0.06 (in /home/kari/.qgis2/python/
>>>> plugins/Qgis2threejs)
>>>> Available version: 0.6 (in QGIS Official Plugin Repository)
>>>> - those leading zeroes ?
>>> Please try to wipe out .qgis2 folder and re-install the plugins.
>>>> 2. jp2 (Jpeg2000) files don't work/render at all. That was not a
>>>> surprise in
>>>> OpenSuse. Have to force kill and restart qgis.
>>> It is a surprise to me, openSUSE was the first distribution to have
>>> OpenJPEG v2 packaged in Factory...
>>> Plus, I can work with jp2 files in 13.1
>>> Can you please provide a jp2 file that fails for you so I can test?
>>>> 3. in About -> License is missing (totally white) ;)
>>> Confirmed, I will take a look at this, thanks.
>>>> Regards,
>>>> Kari
>>>> PS. Installation
>>>> QGIS version    2.2.0-Valmiera    QGIS code revision    exported
>>>> Compiled against Qt    4.8.4    Running against Qt    4.8.4
>>>> Compiled against GDAL/OGR    1.10.1    Running against GDAL/OGR 1.10.1
>>>> Compiled against GEOS    3.4.2-CAPI-1.8.2    Running against GEOS
>>>> 3.4.2-CAPI-1.8.2 r3921
>>>> PostgreSQL Client Version    9.2.4    SpatiaLite Version 4.1.1
>>>> QWT Version    5.2.3    PROJ.4 Version    480
>>>> QScintilla2 Version
>>>> Kari Salovaara
>>>> Hanko, Finland
>>>> "Volunteers do not necessarily have the time; they just have the heart."
>>>> ~Elizabeth Andrew
>>> Thank you for your feedback.
>>> Best,
>>> Angelos
>> Kari Salovaara
>> Hanko, Finland
>> ~Elizabeth Andrew
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140226/167f393b/attachment-0001.html>
