[Qgis-developer] Atlas export Python script not working in 2.2
Alexandre Neto
senhor.neto at gmail.com
Thu Feb 27 03:41:28 PST 2014
Hello matt,
That must have to do with the fact that now it's possible to control more
that one map extent with atlas, that means that for each map item you need
to check the control by atlas option.
The same probably applies to the python scripts.
Hope I helped,
Alexandre Neto
On Thu, Feb 27, 2014 at 11:19 AM, mattwalsh <matthew at miningsearchesuk.com>wrote:
> Hello,
> I am having a bit trouble migrating a script to QGIS 2.2.
> In QGIS 2.0 I have the following Python script which will load a composer
> from template, generate an atlas and export to image.
> myFile = os.path.join(os.path.dirname(__file__), template)
> myTemplateFile = file(myFile, 'rt')
> myTemplateContent = myTemplateFile.read()
> myTemplateFile.close()
> myDocument = QDomDocument()
> myDocument.setContent(myTemplateContent)
> myComposition.loadFromTemplate(myDocument)
> # Get map composition and define scale
> myAtlasMap = myComposition.getComposerMapById(0)
> myAtlasMap.setNewScale(int(scale))
> # Setup Atlas
> myAtlas = QgsAtlasComposition(myComposition)
> myAtlas.setCoverageLayer(atlas_desktop)
> myAtlas.setComposerMap(myAtlasMap)
> myAtlas.setFixedScale(True)
> myAtlas.fixedScale()
> myAtlas.setHideCoverage(False)
> myAtlas.setFilterFeatures(True)
> myAtlas.setFeatureFilter("reference = '%s'" % (str(ref)))
> print myAtlas.composerMap()
> # Generate atlas
> myAtlas.beginRender()
> for i in range(0, myAtlas.numFeatures()):
> myAtlas.prepareForFeature( i )
> jobs = r"\\myserver\a folder\Jobs"
> job_fol = os.path.join(jobs, str(ref))
> if not os.path.exists(job_fol):
> os.makedirs(job_fol)
> output_jpeg = os.path.join(job_fol, ref + "_BMS_plan.jpg")
> myImage = myComposition.printPageAsRaster(0)
> myImage.save(output_jpeg)
> myAtlas.endRender()
> if os.path.isfile(output_jpeg) is False:
> QMessageBox.warning(self.iface.mainWindow(), "Uh Oh!",
> "Something went wrong, no image exported!")
> return
> else:
> return
> In QGIS 2.2 this script is no longer working correctly. The template is
> loaded and a map is exported to image, however, the map does not display
> the
> correct area. The map area draws the correct layers but the extent is wrong
> (no where near the feature from the atlas). Had a look at the documentation
> and wasn't really able to see what has changed/deprecated?
> Thanks
> Matt
> http://osgeo-org.1560.x6.nabble.com/Atlas-export-Python-script-not-working-in-2-2-tp5106328.html
> Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140227/58d839fb/attachment.html>
