[Qgis-developer] D&D form gone?
Rémi Bovard remi.bovard at gmail.com
Fri Feb 28 06:29:15 PST 2014
Nobody else has this issue?
Because of it, when I add a feature in a PostGIS layer, the form is empty
because by default the form is set as "drag and drop".
It's really annoying...
Thanks for your feedbacks.
Rémi
2014-02-27 18:35 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 27/02/2014 11:51, Rémi Bovard ha scritto:
> > With shapefile layers, the combobox is filled with "auto generated". But
> > with PostGIS layers, the combobox is filled by default with "drag and
> > drop". So if the option "Open the form if only one feature is selected"
> > is checked, the form open with nothing inside it...
> > Can someone else confirm it?
> not confirmed here
> thanks
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140228/a391819e/attachment.html>
