[Qgis-developer] QGIS Web Client improvements
aperi2007 aperi2007 at gmail.com
Fri Jan 3 06:53:18 PST 2014
Sorry, I don't understand before.
Obviously this mean that this solution is not for external wms where
there isn't this little php addon.
Only for direct accessible server where is possible to add this
php/python addon.
Also perhaps is better to add a vendor-specific parameter to the
getcapabilites of qgis.
So you have no problem in evolutions of projects .qgs file formats
A.
On 03/01/2014 15:45, Alessandro Pasotti wrote:
> 2014/1/3 aperi2007 <aperi2007 at gmail.com <mailto:aperi2007 at gmail.com>>
>     The RULE ?
>     It need to know exactly the class name,
>     but AFAIK the rule name is not available from the GetCapabilities
>     don't ?
> Yes, but as I wrote, with a small Python/PHP helper that parses the
> project file we can get that information and bind the two.
> The SVG legend (if contains proper attributes to build the FILTER)
> would work without an additional helper.
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140103/fdfb6804/attachment.html>
