[Qgis-developer] QGIS Server SLD GetStyles method bug?
rldhont
rldhont at gmail.com
Fri Jan 3 09:34:56 PST 2014
Le 03/01/2014 18:09, Alessandro Pasotti a écrit :
> 2014/1/3 rldhont <rldhont at gmail.com <mailto:rldhont at gmail.com>>
> Hi,
> It's just because the STYLE parameter is mandatory in GetMap
> Request and GetStyle is based on it.
> If QGIS-Server will implement multi-styles, STYLE parameter will
> be usefull like in GetMap.
> Thanks,
> just to be sure: are you saying that GetStyle implementation in QGIS
> Mapserver is based on GetMap and hence the parameter is needed (even
> if unused) or that the OGC standard says that GetStyle is kind of sub
> method of GetMap and it requires all mandatory parameters of GetMap?
Yes, but GetStyle is not an OGC defined method.
The method defined by OGC is GetStyles to retrieve all the layer's styles.
You can open a bug, and discussing about GetStyle and GetStyles request.
Reagrds,
René-Luc D'Hont
3Liz
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140103/357c97d3/attachment.html>
