[Qgis-developer] [Plugin] QGIS Web Processing Client
Pirmin Kalberer
pi_ml at sourcepole.com
Tue Jan 7 00:30:43 PST 2014
Hi René-Luc
Thanks for your work! I will make the Processing integration backwards
compatible with QGIS 1.8 (see also [1]) to keep the plugin maintainable.
Regards
Pirmin
[1] https://github.com/pka/qgis-apicompat-plugin
Am Freitag, 3. Januar 2014, 15.45:35 schrieb rldhont:
> Hi Horst,
> I have updated your QGIS Web Processing Client.
> I have put the code on github : https://github.com/rldhont/qgis-wps-client
> You can update the version on the QGIS plugin repository.
> Hi devs,
> You can test it and contribute.
> Regards,
> René-Luc D'Hont
> 3Liz
> Qgis-developer mailing list
Pirmin Kalberer
Sourcepole - Linux & Open Source Solutions
http://www.sourcepole.com
