[Qgis-developer] Ideas/proposal for Attribute Table
Bernhard Ströbl
bernhard.stroebl at jena.de
Tue Jan 7 02:50:24 PST 2014
Hm,
if you look at JasperReports it is Java. Can you implement this
internally into QGIS? Looking at reports in general some kind of
programming will always be needed to generate an individual report
because the data structure is individual, too, so I think it will always
be something for specialists.
An idea to start with would be to create a new element in Composer that
makes simple calculations like sum or average on a field: Choose layer -
choose field - choose what to do. Evaluation time will be the same as
for the map (either permanetly or on request but at least before printing).
Bernhard
Am 07.01.2014 11:16, schrieb Paolo Cavallini:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Il 06/01/2014 10:40, Bernhard Ströbl ha scritto:
>> the need to create some kind of reports is often uttered. IMHO a dedicated reporting
>> tool can always handle this better than anything implemented in QGIS or any other GIS
>> (because it is not a main GIS feature). I successfully coupled a Python
>> implementation of JasperReports [1] with QGIS. JasperReports not only allows
>> sum/average and the like but also subreports (for ?:n relations) charts and much
>> more. AFAIK (but have not tried myself) LibreOffice output is possible, too. This
>> solution needs some Python programming to create an XML document from your data and
>> send the data and the report template to the server.
> Hi all.
> I agree this is an important issue. I heard there was some plan to implement this:
> anyone knows the current status, and the prospects for the future?
> Obviously, we have always the same duality: implementing outside QGIS is easier and
> more powerful, reusing existing tools, whereas an internal implementation is far
> smoother from an user point of view.
> Historically, in most analogous cases we ended up implementing an internal solution
> (sometimes using common libs), and I suspect sooner or later we'll have to do the
> same for reporting also.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.15 (GNU/Linux)
> Comment: Using GnuPG with Icedove - http://www.enigmail.net/
> iEUEARECAAYFAlLL0/kACgkQ/NedwLUzIr4XCwCgr/C2zJT8KOZqXW2BOQvr5kfT
> AnMAlRyAp4wxoChEMxz8T4L/KaQnsSI=
> =d9ww
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
__________ Information from ESET Mail Security, version of virus signature database 9258 (20140107) __________
The message was checked by ESET Mail Security.
http://www.eset.com
