[Qgis-developer] [Plugin] QGIS Web Processing Client
rldhont
rldhont at gmail.com
Tue Jan 7 03:20:43 PST 2014
hi Luca,
It's seem that there are an error in QgsWpsDockWidget.py:34
We have : from wps.wpslib.processdescription import ..
We should have : from wpslib.processdescription import ..
You can correct it
Le 07/01/2014 12:13, Luca Delucchi a écrit :
> On 3 January 2014 15:45, rldhont <rldhont at gmail.com> wrote:
>> Hi Horst,
> Hi,
>> I have updated your QGIS Web Processing Client.
>> I have put the code on github : https://github.com/rldhont/qgis-wps-client
> I downloaded the master but I obtain this error
> Traceback (most recent call last):
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 204, in
> startPlugin
> plugins[packageName] = package.classFactory(iface)
> File "/home/lucadelu/.qgis2/python/plugins/qgis-wps-client-master/__init__.py",
> line 50, in classFactory
> from qgswps import QgsWps
> File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 453, in _import
> mod = _builtin_import(name, globals, locals, fromlist, level)
> File "/home/lucadelu/.qgis2/python/plugins/qgis-wps-client-master/qgswps.py",
> line 23, in
> from QgsWpsDockWidget import QgsWpsDockWidget
> File "/home/lucadelu/.qgis2/python/plugins/qgis-wps-client-master/QgsWpsDockWidget.py",
> line 34, in
> from wps.wpslib.processdescription import StringInput, TextInput,
> SelectionInput, VectorInput, MultipleVectorInput, RasterInput,
> MultipleRasterInput, FileInput, MultipleFileInput, ExtentInput,
> CrsInput, VectorOutput, RasterOutput, StringOutput
> ImportError: No module named wpslib.processdescription
>> You can update the version on the QGIS plugin repository.
>> Hi devs,
>> You can test it and contribute.
>> Regards,
>> René-Luc D'Hont
>> 3Liz
