[Qgis-developer] Date/time widget
Tim Sutton
lists at linfiniti.com
Wed Jan 8 05:36:17 PST 2014
Hi
On Wed, Jan 8, 2014 at 1:00 PM, Matthias Kuhn <matthias.kuhn at gmx.ch> wrote:
> Hi Paolo,
> I'm currently working on a refactoring of the editor widgets, mainly to
> make them work asynchronously. This will make them much more pleasant to
> use and to maintain and open up new possibilities such as having non-modal
> attribute dialogs.
> This means, that at the moment, I would not recommend to touch this code,
> but instead to wait for these changes to be merged. I will publish a branch
> for testing in the next days.
> Amongst other things, also Issue #4417 [1] is solved, with code provided
> by Danial Vaz in the long-standing PR752 [2]
> If there is sponsoring available for fixing the date-time issue, please
> let me know and I will happily include this in the refactoring work.
By the way - unless something has changed, the 'drag and drop' form
designer is badly named - it doesn't allow either dragging or dropping.
Perhaps it should be renamed to 'Interactive form designer' or something?
Regards
Tim
> Best
> Matthias
> [1] https://hub.qgis.org/issues/4417
> [2] https://github.com/qgis/QGIS/pull/752
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140108/e33e4c08/attachment.html>
