[Qgis-developer] please help me :(
Tim Sutton lists at linfiniti.com
Fri Jan 10 00:26:50 PST 2014
Hi
Could you please use a descriptive subject line for your messages (e.g.
'Problem compiling QGIS 1.7 on Ubuntu 12.04') instead of 'Please help me'.
On Fri, Jan 10, 2014 at 2:08 AM, otmane yazidi alaoui <
yazidiotmane at gmail.com> wrote:
> i have this problem
> [ 0%] Built target svnversion
> [ 1%] Built target t2tdoc
> [ 17%] Built target qgis_core
> [ 24%] Built target ui
> [ 34%] Built target qgis_gui
> [ 37%] Built target qgis_analysis
> [ 63%] Built target qgis
> [ 66%] Built target translations
> [ 66%] Built target compile_python_files
> [ 67%] Built target python_module_qgis_analysis
> [ 67%] Building CXX object
> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart0.cpp.o
> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart1.cpp.o
> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp: In
> function ‘PyObject* meth_QgsSymbolV2_renderHints(PyObject*, PyObject*)’:
> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp:6719:42:
> error: passing ‘const QgsSymbolV2’ as ‘this’ argument of ‘int
> QgsSymbolV2::renderHints()’ discards qualifiers [-fpermissive]
> function ‘PyObject* meth_QgsSymbolV2RenderContext_setSelected(PyObject*,
> PyObject*)’:
> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp:7121:35:
> error: passing ‘const QgsSymbolV2RenderContext’ as ‘this’ argument of ‘void
> QgsSymbolV2RenderContext::setSelected(bool)’ discards qualifiers
> [-fpermissive]
> make[2]: ***
> [python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart1.cpp.o]
> Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
> make: *** [all] Error 2
> 00:03:40: Le processus "/usr/bin/make" s'est terminé avec le code 2.
> Erreur à la compilation du projet qgis1.7.0 (cible : Desktop)
> Lors de l'exécution de l'étape "Make"
Any reason why you are trying to build such an old version of QGIS?
Regards
Tim
>        YAZIDI ALAOUI OTMANE
>            Ingénieur d'état en Géomatique
>                    Tel:+212652538743
>                    @ :yazidiotmane at gmail.com
> http://www.doyoubuzz.com/otmane-yazidi-alaoui
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140110/29d90d5f/attachment.html>
