[Qgis-developer] please help me :(
Tim Sutton
lists at linfiniti.com
Sun Jan 12 22:41:31 PST 2014
Otmane
So I suggest:
* build with current master or at minimum qgis 2.0.1 stable release
* send complete details of what operating system you are on
* send complete details of how you installed dependencies for QGIS
I suggest simply starting a new thread following my hints on how to write
an informative question earlier in this thread.
Regards
Tim
On Fri, Jan 10, 2014 at 2:52 PM, Etienne Tourigny
<etourigny.dev at gmail.com>wrote:
> also, why would you build qgis 1.7 which is an old release?
> On Thu, Jan 9, 2014 at 10:08 PM, otmane yazidi alaoui <
> yazidiotmane at gmail.com> wrote:
>> i have this problem
>> [ 0%] Built target svnversion
>> [ 1%] Built target t2tdoc
>> [ 17%] Built target qgis_core
>> [ 24%] Built target ui
>> [ 34%] Built target qgis_gui
>> [ 37%] Built target qgis_analysis
>> [ 63%] Built target qgis
>> [ 66%] Built target translations
>> [ 66%] Built target compile_python_files
>> [ 67%] Built target python_module_qgis_analysis
>> [ 67%] Building CXX object
>> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart0.cpp.o
>> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart1.cpp.o
>> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp:
>> In function ‘PyObject* meth_QgsSymbolV2_renderHints(PyObject*, PyObject*)’:
>> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp:6719:42:
>> error: passing ‘const QgsSymbolV2’ as ‘this’ argument of ‘int
>> QgsSymbolV2::renderHints()’ discards qualifiers [-fpermissive]
>> In function ‘PyObject* meth_QgsSymbolV2RenderContext_setSelected(PyObject*,
>> PyObject*)’:
>> /home/alaoui/dev/cpp/qtcreator-build-qgis/python/core/sipcorepart1.cpp:7121:35:
>> error: passing ‘const QgsSymbolV2RenderContext’ as ‘this’ argument of ‘void
>> QgsSymbolV2RenderContext::setSelected(bool)’ discards qualifiers
>> [-fpermissive]
>> make[2]: ***
>> [python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart1.cpp.o]
>> Error 1
>> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
>> make: *** [all] Error 2
>> 00:03:40: Le processus "/usr/bin/make" s'est terminé avec le code 2.
>> Erreur à la compilation du projet qgis1.7.0 (cible : Desktop)
>> Lors de l'exécution de l'étape "Make"
>> YAZIDI ALAOUI OTMANE
>> Ingénieur d'état en Géomatique
>> Tel:+212652538743
>> @ :yazidiotmane at gmail.com
>> http://www.doyoubuzz.com/otmane-yazidi-alaoui
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140113/df91a048/attachment.html>
