[Qgis-developer] Approximation and geoprocessing
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Jan 13 00:12:41 PST 2014
it depends...
Processing works as follows: take input layer(s) - do a process - create
output layer
So if the "process" is a selection the result is an output layer with
only the selected features included.
Therefore for "eliminate" I included a simple logical selection based on
a field in the layer. Thus to use eliminate in a model you first have to
create an input layer with a field that somehow marks all features to be
eliminated (e.g. caluclate area/perimeter). Currently I do not know how
this can be achieved. :-(
Any hints welcome.
Bernhard
Am 10.01.2014 16:04, schrieb kimaidou:
> Hi all,
> If I understood correctly, someone added very recently the support of
> QgsExpressions in the processing toolbox. This could help I suppose ?
> Michael
> 2014/1/10 Alexander Bruy <alexander.bruy at gmail.com
> <mailto:alexander.bruy at gmail.com>>
> Hi Bernhard,
> there is a good article about Advanced Field Calculator [0], but
> only in Russian (there is a Google Translate in the right sidebar).
> Hope this helps a bit
> [0] http://gis-lab.info/qa/fieldpyculator.html
> 2014/1/10 Bernhard Ströbl <bernhard.stroebl at jena.de
> <mailto:bernhard.stroebl at jena.de>>:
> > Hi,
> > I provided "eliminate sliver polygons" in the processing
> framework some
> > months ago (thanks for your help, Victor!). Eliminate is based on
> a certain
> > field. You would have to calculate the area (or area/perimeter)
> for all
> > polygons and use that as a threshold in "Eliminate sliver
> polygons". No idea
> > how to calculate that, though. How does the "Advanced python field
> > caluclator work"?
> > Bernhard
> > Am 10.01.2014 15:18, schrieb Andreas Neumann:
> >> Hi,
> >> I don't have a solution for the problem.
> >> But I can confirm that the whole analysis chain is a bit problematic
> >> with all these precision issues. As an example if you test
> intersections
> >> of buildings against parcels (2 different layers) and the building
> >> touches the parcel borders you may get very tiny intersects with
> parcels
> >> (only a few square cms) and you wouldn't want to include these
> >> intersections in your analysis.
> >> So it would be cool if for geometry tests there could be a notion of
> >> threshold values. If the area of an intersected polygon is below
> this
> >> value it wouldn't be taken into account during the analysis.
> >> These issues are really kind of show-stoppers and almost always
> require
> >> intermediate steps to sort out these edge cases. It would be
> very handy
> >> if the tools could handle this precision/uncertainty problems
> without
> >> having to do a lot of intermediate steps.
> >> Andreas
> >> Am 10.01.2014 15:01, schrieb Paolo Cavallini:
> >>> Hi all.
> >>> I got into an interesting problem, before opening a few tickets
> I'd like
> >>> to discuss a line of action.
> >>> 1. Some sw (namely geomedia) produces shapefiles with very slight
> >>> differences (same layer, modified and exported several times);
> I suppose
> >>> this is due to truncation/approximation in coordinate precision.
> >>> 2. As a result, the diff between these layers produces a number of
> >>> virtually 0 width polygons, and some topological errors.
> >>> 3. This in turn leads to 2 problems:
> >>> 3.1. subsequent analyses fail because of the errors, and the
> user has no
> >>> clue about the reasons
> >>> 3.2. The microareas are tricky and time consuming to remove (if
> they are
> >>> isolated, a possible solution is to select and remove those
> smaller than
> >>> an arbitrary threshold, but if they are linked to some "real"
> polygons,
> >>> this will not work).
> >>> I would therefore suggest a few improvements over the
> toolchain, i.e.:
> >>> * add a parameter in analyses, to either snap original data
> within a
> >>> threshold before running the analysis, or to clean up the results
> >>> afterwards
> >>> * check& warn the user of topo errors in source layers, and of
> possible
> >>> wrong results; maybe this should be optional, as this will slow
> down the
> >>> analysis, and may be useless after first cleanup.
> >>> Sample data available for those interested.
> >>> All the best.
> >> _______________________________________________
> >> Qgis-developer mailing list
> >> Qgis-developer at lists.osgeo.org
> <mailto:Qgis-developer at lists.osgeo.org>
> >> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> __________ Information from ESET Mail Security, version of virus
> signature
> >> database 9274 (20140110) __________
> >> The message was checked by ESET Mail Security.
> >> http://www.eset.com
> signature
> > http://www.eset.com
> Alexander Bruy
> Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
__________ Information from ESET Mail Security, version of virus signature database 9281 (20140112) __________
http://www.eset.com
